With the machine on, go to the Quick Settings in the Home Menu.
Select the "Level Table" option.
Select "Home XYZ" so that the head goes to the starting position.
The leveling should be performed on the 4 points of the table, as shown in the figure.
Select the "Set P1" option to level the table height at the first point.
The nozzle should be slightly away from the glass (thickness of a sulphite sheet).
To bring the table closer to the nozzle, turn the rosette clockwise.
To move the table away from the spout, rotate the rosette counterclockwise.
Ready! Your table is level!
由衷感谢以下译者:
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
