跳转到主内容
Table Lamp Bulb and Wiring Replacement
你所需要的
  1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: 步骤 1 中的图像 1,1
    • Switch off the lamp to ensure no electricity is flowing.
    • Unplug the lamp from the power outlet to prevent the risk of electric shock.
    • Wait a few minutes to allow any remaining electrical charge to dissipate.
  2. Table Lamp Bulb and Wiring Replacement: 步骤 2 中的图像 1,1
    • Locate the screw at the base of the lamp that secures the light fixture to the structure.
    • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
    • Keep the screw in a secure place to avoid losing it during reassembly.
  3. Table Lamp Bulb and Wiring Replacement: 步骤 3 中的图像 1,1
    • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
    • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
  4. Table Lamp Bulb and Wiring Replacement: 步骤 4 中的图像 1,3 Table Lamp Bulb and Wiring Replacement: 步骤 4 中的图像 2,3 Table Lamp Bulb and Wiring Replacement: 步骤 4 中的图像 3,3
    • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
    • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
  5. Table Lamp Bulb and Wiring Replacement: 步骤 5 中的图像 1,3 Table Lamp Bulb and Wiring Replacement: 步骤 5 中的图像 2,3 Table Lamp Bulb and Wiring Replacement: 步骤 5 中的图像 3,3
    • Take off the white cover from bottom to top.
  6. Table Lamp Bulb and Wiring Replacement: 步骤 6 中的图像 1,2 Table Lamp Bulb and Wiring Replacement: 步骤 6 中的图像 2,2
    • Cut both of the old wires with wire cutters.
  7. Table Lamp Bulb and Wiring Replacement: 步骤 7 中的图像 1,2 Table Lamp Bulb and Wiring Replacement: 步骤 7 中的图像 2,2
    • Take out the new wire and make sure lamp wires correlate to its terminal.
    • Neutral is marked blue, hot is marked red.
  8. Table Lamp Bulb and Wiring Replacement: 步骤 8 中的图像 1,1
    • Thread the wire through the small hole under the lamp.
  9. Table Lamp Bulb and Wiring Replacement: 步骤 9 中的图像 1,2 Table Lamp Bulb and Wiring Replacement: 步骤 9 中的图像 2,2
    • Secure the wires to the screws using a Phillips screwdriver.
    • Tighten the screws so that the wires are secured under the screws.
  10. Table Lamp Bulb and Wiring Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips screwdriver to screw the wire between its correlating screw.
    • Blue is neutral, red is hot.
  11. Table Lamp Bulb and Wiring Replacement: 步骤 11 中的图像 1,1
    • Plug the lamp in, and the bulb will light up.
终点
Jeffrey Cong
于02/19/25注册
193 声望
撰写一个指南
团队
UC Davis, Team 3-3, Andersen Winter 2025 UC Davis, Team 3-3, Andersen Winter 2025 的会员
UCD-ANDERSEN-W25S3G3
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 324
