简介
If your 6-8 inch Personal Table Fan has been lagging or the blades have broke. Use this guide to replace the blades in your fan.
Before using this guide, make sure your fan works when plugged in. If it does not, the blades are not the issue, the motor is and this guide will not fix the issue.
Before beginning, make sure to unplug your fan.
你所需要的
Use a prying tool to loosen the front cover.
After it is pried loose, remove the cover.
终点
另外一个人完成了本指南。
