跳转到主内容
加入维修社区 - 创建账户
TYLT VU Wireless charging car mount Disassembly
你所需要的
    1. TYLT VU Wireless charging car mount Disassembly, Removing the front panel: 步骤 1 中的图像 1,2 TYLT VU Wireless charging car mount Disassembly, Removing the front panel: 步骤 1 中的图像 2,2
      • First thing you want to do is lift up the corners of the rubber mat that makes up the center that your phone sits on. Here you will find 4 screws (One in each corner). Remove these screws and the whole front panel should come off.
      询问修复机器人
      添加评论
    2. TYLT VU Wireless charging car mount Disassembly, Disconnecting the front panel: 步骤 2 中的图像 1,1
      • Next you need to be careful not to brake any of the 3 wires running from the main charging circuit to the power intake port, that sits on a seperate chip in the bottom housing. This is held on by 1 screw.
      询问修复机器人
      添加评论
    3. TYLT VU Wireless charging car mount Disassembly: 步骤 3 中的图像 1,3 TYLT VU Wireless charging car mount Disassembly: 步骤 3 中的图像 2,3 TYLT VU Wireless charging car mount Disassembly: 步骤 3 中的图像 3,3
      • Now your should be left with this bottom part. To get to the sprockets and the locking mechanism inside, you need to remove the plate that is secured with 4 screws + 1 smaller screw. When that plate is removed (might take some slight convincing) you will see the sprockets and mechanism seen in picture 2 and 3.
      询问修复机器人
      添加评论
    4. TYLT VU Wireless charging car mount Disassembly: 步骤 4 中的图像 1,1
      • Mind the small spring in picture 1 when assembling, this pulls both the clamps out when the button is pushed. Also remember to realign all the parts when assembling. Other than that it is the reverse of dissasembling.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 38
总计 1,735
