跳转到主内容
TRS-80 Color Computer Power Cord Replacement
你所需要的
  1. TRS-80 Color Computer Power Cord Replacement, Outside Casing: 步骤 1 中的图像 1,1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Power Cord Replacement: 步骤 2 中的图像 1,2 TRS-80 Color Computer Power Cord Replacement: 步骤 2 中的图像 2,2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Power Cord Replacement, Keyboard: 步骤 3 中的图像 1,2 TRS-80 Color Computer Power Cord Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Power Cord Replacement, Motherboard: 步骤 4 中的图像 1,3 TRS-80 Color Computer Power Cord Replacement, Motherboard: 步骤 4 中的图像 2,3 TRS-80 Color Computer Power Cord Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Power Cord Replacement: 步骤 5 中的图像 1,3 TRS-80 Color Computer Power Cord Replacement: 步骤 5 中的图像 2,3 TRS-80 Color Computer Power Cord Replacement: 步骤 5 中的图像 3,3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Power Cord Replacement, Power Cord: 步骤 6 中的图像 1,2 TRS-80 Color Computer Power Cord Replacement, Power Cord: 步骤 6 中的图像 2,2
    • Remove the two 1.6 inch screws securing the transformer.
  7. TRS-80 Color Computer Power Cord Replacement: 步骤 7 中的图像 1,1
    • Remove the power cord's three leads from the transformer.
    • Note the orientation and color of the three leads. Make sure to replace these exactely as they were.
  8. TRS-80 Color Computer Power Cord Replacement: 步骤 8 中的图像 1,2 TRS-80 Color Computer Power Cord Replacement: 步骤 8 中的图像 2,2
    • Using needle-nose pliers, pinch the tabs of the grommet holding the power cord to the case and push the grommet out.
    • Remove the entire length of cord from the case and replace with a new one.
结论
5等其他人完成本指南。
团队
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G24
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,321
