跳转到主内容
TRS-80 Color Computer Motherboard Replacement
你所需要的
  1. TRS-80 Color Computer Motherboard Replacement, Outside Casing: 步骤 1 中的图像 1,1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Motherboard Replacement: 步骤 2 中的图像 1,2 TRS-80 Color Computer Motherboard Replacement: 步骤 2 中的图像 2,2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Motherboard Replacement, Keyboard: 步骤 3 中的图像 1,2 TRS-80 Color Computer Motherboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,3 TRS-80 Color Computer Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,3 TRS-80 Color Computer Motherboard Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Motherboard Replacement: 步骤 5 中的图像 1,3 TRS-80 Color Computer Motherboard Replacement: 步骤 5 中的图像 2,3 TRS-80 Color Computer Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
结论
5等其他人完成本指南。
Andrew
于01/23/11注册
530 声望
创作了2篇指南
团队
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G24
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 4,280
