跳转到主内容
TRS-80 Color Computer Keyboard Replacement
你所需要的
  1. TRS-80 Color Computer Keyboard Replacement, Outside Casing: 步骤 1 中的图像 1,1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Keyboard Replacement: 步骤 2 中的图像 1,2 TRS-80 Color Computer Keyboard Replacement: 步骤 2 中的图像 2,2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 TRS-80 Color Computer Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G24
4 名成员
创作了10篇指南
1指南评论
This only applies for Color Computers issued after the CoCo 1 F Board (as shown) RS catalog 26-3004 and subsequent models (CoCo 2 & 3). Early editions of the CoCo 1 had not a mylar ribbon cable like this but a heavier ribbon composed of actual wires, the connector they went into was also built for this type of ribbon. The keyboards on each category of connecting ribbon are sadly not interchangeable.
Rogelio Perea - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 3,471
