跳转到主内容
TRS-80 Color Computer Fuse Replacement
你所需要的
  1. TRS-80 Color Computer Fuse Replacement, Outside Casing: 步骤 1 中的图像 1,1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Fuse Replacement: 步骤 2 中的图像 1,2 TRS-80 Color Computer Fuse Replacement: 步骤 2 中的图像 2,2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Fuse Replacement, Keyboard: 步骤 3 中的图像 1,2 TRS-80 Color Computer Fuse Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Fuse Replacement, Motherboard: 步骤 4 中的图像 1,3 TRS-80 Color Computer Fuse Replacement, Motherboard: 步骤 4 中的图像 2,3 TRS-80 Color Computer Fuse Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Fuse Replacement: 步骤 5 中的图像 1,3 TRS-80 Color Computer Fuse Replacement: 步骤 5 中的图像 2,3 TRS-80 Color Computer Fuse Replacement: 步骤 5 中的图像 3,3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Fuse Replacement, Fuse: 步骤 6 中的图像 1,2 TRS-80 Color Computer Fuse Replacement, Fuse: 步骤 6 中的图像 2,2
    • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
  7. TRS-80 Color Computer Fuse Replacement: 步骤 7 中的图像 1,3 TRS-80 Color Computer Fuse Replacement: 步骤 7 中的图像 2,3 TRS-80 Color Computer Fuse Replacement: 步骤 7 中的图像 3,3
    • Remove the power cable jumpers from the power supply.
  8. TRS-80 Color Computer Fuse Replacement: 步骤 8 中的图像 1,1
    • Gently peel back the protective film on the top of the transformer.
  9. TRS-80 Color Computer Fuse Replacement: 步骤 9 中的图像 1,3 TRS-80 Color Computer Fuse Replacement: 步骤 9 中的图像 2,3 TRS-80 Color Computer Fuse Replacement: 步骤 9 中的图像 3,3
    • Locate the two points the fuse is soldered into the circuit board.
    • Using a soldering iron and soldering wick, desolder and remove the fuse.
    • Place the new fuse into the location of the old one, and solder it in place.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G24
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 2,769
