跳转到主内容
TOSHIBA Satellite E45W-C4200X Screen Replacement
你所需要的
  1. TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: 步骤 1 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Using a plastic opening tool, remove the plastic bar underneath the screen.
    • Use caution when removing the plastic bar to prevent cracking.
  2. TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver and remove the four screws at the bottom of the screen.
    • Be sure to store the screws in a safe place to prevent losing them.
  3. TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 3 中的图像 1,3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 3 中的图像 2,3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 3 中的图像 3,3
    • Use the blue plastic opening tool to start separating the plastic cover from the screen.
    • Once started, use the Jimmy to run along the edges to complete the separation.
    • Be sure to go very slow to avoid cracking the glass further and possibly cutting yourself.
    • The camera is still connecting the protective cover to the laptop; we recommend setting it on top of the keyboard.
  4. TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the remaining screws that hold the screen in place using the Phillips #1 screwdriver.
    • Carefully lift out the screen and fold on its face.
    • The screen is still attached, do not pull away from the laptop.
  5. TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 5 中的图像 1,3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 5 中的图像 2,3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 步骤 5 中的图像 3,3
    • Disconnect the screen from the small circuit board.
    • Gently disconnect with even pressure on both sides to prevent damage.
    • The old screen has now been completely removed.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 36
总计 1,800
