跳转到主内容
TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
你所需要的
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: 步骤 1 中的图像 1,2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: 步骤 1 中的图像 2,2
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 2 中的图像 1,2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 2 中的图像 2,2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 3 中的图像 1,2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 4 中的图像 1,3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 4 中的图像 2,3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 步骤 4 中的图像 3,3
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
结论
另外一个人完成了本指南。
一条评论
Thanks for this. Great help in sorting out my laptop.
Jack - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 582
