跳转到主内容
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
你所需要的
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 2,2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 2 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 3 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 4 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 5 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 6 中的图像 1,3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 6 中的图像 2,3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 步骤 6 中的图像 3,3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
结论
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 348
