跳转到主内容
TOSHIBA Satellite E45W-C4200X Battery Replacement
你所需要的
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: 步骤 1 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 2 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 2 中的图像 2,2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 3 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 3 中的图像 2,2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 4 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 5 中的图像 1,2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 5 中的图像 2,2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the laptop.
结论
3等其他人完成本指南。
一条评论
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 33
总计 2,044
