跳转到主内容
TI-Nspire Battery Replacement
你所需要的
  1. TI-Nspire Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
    • Slide the front cover down to remove it.
  2. TI-Nspire Battery Replacement: 步骤 2 中的图像 1,2 TI-Nspire Battery Replacement: 步骤 2 中的图像 2,2
    • The calculator should be facing front with the screen on the top and the keypad on the bottom.
    • Hold the long side of the calculator on the right or left and turn it 180 degrees so that the back of the calculator faces you.
    • Make sure that the current side facing you is the back by checking that the side has a "reset" button.
  3. TI-Nspire Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
    • Slide the switch until it moves from the left side of the button area all the way to the right side.
    • Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
  4. TI-Nspire Battery Replacement: 步骤 4 中的图像 1,1
    • Turn the calculator back to the front as you would normally use it.
  5. TI-Nspire Battery Replacement: 步骤 5 中的图像 1,2 TI-Nspire Battery Replacement: 步骤 5 中的图像 2,2
    • Put your hand on the keypad, slide the keypad down about a half inch, and pull up to remove the keypad.
  6. TI-Nspire Battery Replacement: 步骤 6 中的图像 1,1
    • The batteries should be on the right and left side in the keypad area, with two on each side.
    • Place the tip of your finger in between the batteries, and remove the batteries. Repeat this for the other side as well.
  7. TI-Nspire Battery Replacement: 步骤 7 中的图像 1,1
    • When reassembling your device, use four new batteries.
结论
To reassemble your device, follow these instructions in reverse order. If your calculator doesn't turn on, it could be that the keypad isn't connected properly. If so, refer to Connecting the Keypad.
7等其他人完成本指南。
Clincy Cheung
于09/26/12注册
223 声望
撰写一个指南
团队
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G52
5 名成员
创作了12篇指南
一条评论
what should i do if it just stopped all of a sudden and my battery isn’t like that? Its a square not like A++
nenene kldbfssm - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 47
总计 17,035
