跳转到主内容
TI-84 Plus Silver Edition Battery Spring Replacement
你所需要的
  1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: 步骤 1 中的图像 1,2 TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: 步骤 1 中的图像 2,2
    • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
  2. TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 2 中的图像 1,2 TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the calculator open.
    • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
  3. TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 3 中的图像 1,1
    • Remove the battery in order to access the battery spring that needs to be replaced.
  4. TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the damaged spring using the tweezers.
  5. TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 5 中的图像 1,2 TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 5 中的图像 2,2
    • Pick up the new spring with the tweezers.
    • Insert the new spring with the tweezers.
    • Gently push the new spring into place using your finger.
  6. TI-84 Plus Silver Edition Battery Spring Replacement: 步骤 6 中的图像 1,1
    • Test by replacing the battery that was taken out to check the connection.
结论
另外一个人完成了本指南。
2条评论
Hi! So where can I get the spring part?
Aleyson B.Hunter - 回复
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 800
