跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
  1. TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: 步骤 1 中的图像 1,3 TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: 步骤 1 中的图像 2,3 TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: 步骤 1 中的图像 3,3
    • External photos.
  2. TELUS Wi-Fi Hub (Arcadyan) Teardown, External Photo 2: 步骤 2 中的图像 1,1
    • External photo 2
  3. TELUS Wi-Fi Hub (Arcadyan) Teardown, Internal Structure: 步骤 3 中的图像 1,2 TELUS Wi-Fi Hub (Arcadyan) Teardown, Internal Structure: 步骤 3 中的图像 2,2
    • A large heatsink on the back of the unit serves to keep the unit cool without installation of a fan.
Christine Tan
于01/08/20注册
117 声望
撰写一个指南
9条评论
Oh nice Absolutely amazing, thank you for sharing your knowledge with me.
Laluna Lawlence - 回复
Thank you for tearing it down. Any hint on the speed of the LAN/WAN port from the hardware?
Ricky Chau - 回复
The router seems to be build on Broadcom’s 6858 SoC which is quite powerful beast and MoCA part is on BCM6802. But I can’t find much details about them.
Ajax - 回复
How was it identified as an Arcadyan NH20A? It says designed in Canada on the bottom. Who makes the Arcadyan NH20A. It's not an easy find.
Arcadyan Headquarters: No.8, Sec.2, Guangfu Rd., Hsinchu City 30071, Taiwan. Not a Canadian company. So it was designed for Canadian use only, care of Telus?
Broadband access, Multimedia and Wireless infrastructure into its expertise.
https://www.arcadyan.com/en-us
Where is it stated that this device is made by Arcadyan? I can't find this device within their company website. Someone must have discovered it labeled on the device, somewhere?
ImaGUIguy - 回复
So this ONT/Modem/Router/Wi-Fi 6 device gets fed a fiber optic cable, straight from outside, or does it go through another device first? Like the old Actiontec T3200M it has a fiber in connector (though isn't used in conjunction with the Nokia G-240G-A ONT) with 1G service plan. My T3200 is just fed a CAT6 ethernet cable from the Nokia. The T3200 is only capable of 1G LAN ethernet, I assume this NH20A device has 2.5G LAN ethernet connectors, using CAT6e or CAT7 cables?
ImaGUIguy - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 65
过去 30 天: 282
总计 19,155
