跳转到主内容
TDK Life on Record Trek Max A34 Large Speaker Replacement
你所需要的
  1. TDK Life on Record Trek Max A34 Large Speaker Replacement, Large Speaker: 步骤 1 中的图像 1,2 TDK Life on Record Trek Max A34 Large Speaker Replacement, Large Speaker: 步骤 1 中的图像 2,2
    • Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
    • Remove the battery cover by pulling up where the screws should go.
  2. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 2 中的图像 1,2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 2 中的图像 2,2
    • Carefully unplug and remove the battery.
    • Use the metal spudger to pry off the rubber bumpers from the bottom of the speaker.
  3. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 3 中的图像 1,3 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 3 中的图像 2,3 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the screws that were underneath the rubber bumpers.
    • Remove the battery holder. Be sure to thread the exposed wires through the hole within the holder.
  4. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 4 中的图像 1,3 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 4 中的图像 2,3 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 4 中的图像 3,3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it more easily.
  5. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 5 中的图像 1,3 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 5 中的图像 2,3 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 5 中的图像 3,3
    • Turn the speaker back upright. Use the metal spudger to pry up the rubber cover to reveal the buttons underneath.
  6. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 6 中的图像 1,2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the screws that hold the top cover in place.
    • Remove the top cover.
  7. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 7 中的图像 1,2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 7 中的图像 2,2
    • On the backside of the device, remove the screws using the Phillips #0 screwdriver.
    • Only the screws on the backside are needed to hold the frame together. Do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  8. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 8 中的图像 1,1
    • Within the device, there is a single cable connecting the large speaker to the motherboard. Unplug this cable.
  9. TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 9 中的图像 1,2 TDK Life on Record Trek Max A34 Large Speaker Replacement: 步骤 9 中的图像 2,2
    • On the front of the device, use the Phillips #0 screwdriver to remove the four screws holding the speaker in.
    • Once the screws are removed, you are able to push the speaker out from behind.
结论
另外一个人完成了本指南。
Mario Lazaga
于01/14/19注册
1 声望
创作了2篇指南
团队
IUPUI, Team S3-G3, Wilson Spring 2019 IUPUI, Team S3-G3, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S3G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 656
