跳转到主内容
TDK Life on Record Trek Max A34 Battery Replacement
你所需要的
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: 步骤 1 中的图像 1,2 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 2 中的图像 1,2 TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 3 中的图像 1,3 TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 3 中的图像 2,3 TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 3 中的图像 3,3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 4 中的图像 1,2 TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 4 中的图像 2,2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: 步骤 5 中的图像 1,1
    • The battery is now separated from the device and may be replaced with a new battery.
结论
8等其他人完成本指南。
Kayla
于09/28/15注册
315 声望
撰写一个指南
团队
Texas Tech, Team 19-3, Rauch Fall 2015 Texas Tech, Team 19-3, Rauch Fall 2015 的会员
TTU-RAUCH-F15S19G3
4 名成员
创作了1篇指南
2条评论
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - 回复
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 11,214
