跳转到主内容
TDK Life on Record Trek 360 Motherboard Replacement
你所需要的
  1. TDK Life on Record Trek 360 Motherboard Replacement, Disassembling TDK Life on Record bottom panel: 步骤 1 中的图像 1,1
    • Remove the four rubber feet of the device using a metal spudger.
  2. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 2 中的图像 1,2 TDK Life on Record Trek 360 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
    • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
  3. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 3 中的图像 1,2 TDK Life on Record Trek 360 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pull the bottom cover of the device towards you.
  4. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 4 中的图像 1,2 TDK Life on Record Trek 360 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the four 13 mm Phillips #1 screws.
  5. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 5 中的图像 1,2 TDK Life on Record Trek 360 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
    • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
    • Pull apart the compartments by applying force in opposite directions.
    • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
  6. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the seven cables attached to the motherboard.
    • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
  7. TDK Life on Record Trek 360 Motherboard Replacement, Air Vent Tube: 步骤 7 中的图像 1,1
    • Remove the four 8 mm Phillips #1 screws.
  8. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 8 中的图像 1,3 TDK Life on Record Trek 360 Motherboard Replacement: 步骤 8 中的图像 2,3 TDK Life on Record Trek 360 Motherboard Replacement: 步骤 8 中的图像 3,3
    • place your hands on each side of the air vent and then place your index finger on the thin plastic half circle that holds the vent in place.
    • Pull the plastic half circle towards you.
    • Put both of your hands inside the tube as shown and push away from you.
  9. TDK Life on Record Trek 360 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 TDK Life on Record Trek 360 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the four wired clips by pulling on the wires.
    • Remove the three 6 mm Phillips #1 screws.
  10. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the volume control knob, which is located at the front of the speaker, by pulling it towards you.
  11. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, turn the nut counter-clockwise and remove the nut.
  12. TDK Life on Record Trek 360 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Push the metal part that holds the volume control knob away from you.
结论
另外一个人完成了本指南。
Helen Huynh
于09/14/15注册
338 声望
创作了3篇指南
团队
CSU Fullerton, Team 1-2, Bruce Fall 2015 CSU Fullerton, Team 1-2, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G2
3 名成员
创作了5篇指南
7条评论
Just a heads up if you take this apart. I took mine apart to fix a broken charge port. When reassembling, the biggest ribbon cable, 8 pins, came disconnected from the sub side (none motherboard side), and I panicked because I could not for the life of me figure out where it was connected to. Upon closer inspection I found the lettering “fwupdate" on the sub end. The sub end has 8 male pins in two rows of four, very similar to a pc motherboard usb 2.0 header. The motherboard side has a white plastic female connector with one row of 8.
This cable is not needed for the speaker to function. I ultimately found where it goes, it was glued to two plastic posts next to the sub behind the battery. In front of it is an opening which is behind the battery. I'm guessing tdk can pull the battery and use the access hole to plug a cable to the 8 male pins for firmware updates. As I dont plan on sending it to tdk for anything, I simply left this cable out, and when reassembled all functions of the speaker work to include bluetooth, aux, volume control, charging, power knob button and power switch, usb port, etc.
Edris A Amiryar - 回复
I thinks that my charge port is broken too, how to be sure ?
Thomas Bousquet - 回复
I just found out my charging port was broken too. I had to pry the power cable to power up the speaker and as soon as I let go it would die. Turns out a weld holding the port to its little pcb craked, welded it back up and now it’s working fine.
vinss_banana - 回复
donde puedo conseguir la placa base del a360
lees_cleypooljc - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,393
