简介
This guide will aid you in replacing your old or worn out battery. Replacing the battery will also increase usage time and enhance all other functions of the device.
你所需要的
Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
3等其他人完成本指南。
2条评论
Good guide, but what battery fits?
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
