跳转到主内容
TDK Life on Record Trek 360 Battery Replacement
你所需要的
  1. TDK Life on Record Trek 360 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
    • Before beginning this guide, be sure that the battery is completely drained of charge. This prevents electrical injury.
  2. TDK Life on Record Trek 360 Battery Replacement: 步骤 2 中的图像 1,3 TDK Life on Record Trek 360 Battery Replacement: 步骤 2 中的图像 2,3 TDK Life on Record Trek 360 Battery Replacement: 步骤 2 中的图像 3,3
    • Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
    • Pull down like a lever while continuing to apply downward pressure.
  3. TDK Life on Record Trek 360 Battery Replacement: 步骤 3 中的图像 1,2 TDK Life on Record Trek 360 Battery Replacement: 步骤 3 中的图像 2,2
    • Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
    • These images show the use of a metal spudger. Use a plastic opening tool or standard spudger to prevent damage to your device.
    • The battery does not lift STRAIGHT UP. Lifting in this manner could damage the battery, wires, and/or the device.
  4. TDK Life on Record Trek 360 Battery Replacement: 步骤 4 中的图像 1,3 TDK Life on Record Trek 360 Battery Replacement: 步骤 4 中的图像 2,3 TDK Life on Record Trek 360 Battery Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
    • Take extreme caution when pulling. This requires some force, but pulling with extreme force can cause damage to the wire/battery/or device.
结论
3等其他人完成本指南。
Helen Huynh
于09/14/15注册
338 声望
创作了3篇指南
团队
CSU Fullerton, Team 1-2, Bruce Fall 2015 CSU Fullerton, Team 1-2, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G2
3 名成员
创作了5篇指南
2条评论
Good guide, but what battery fits?
Niklas Aronsson - 回复
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
Barbafant Fant - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 3,702
