跳转到主内容
TDK Life on Record A33 Battery Replacement
你所需要的
  1. TDK Life on Record A33 Battery Replacement, Battery: 步骤 1 中的图像 1,2 TDK Life on Record A33 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove all (6) 5mm Torx (Star) screws on the bottom panel of the device using the T4 screwdriver.
  2. TDK Life on Record A33 Battery Replacement: 步骤 2 中的图像 1,1
    • Flip up the kickstand to get access to the bottom panel.
  3. TDK Life on Record A33 Battery Replacement: 步骤 3 中的图像 1,3 TDK Life on Record A33 Battery Replacement: 步骤 3 中的图像 2,3 TDK Life on Record A33 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the bottom panel from the A33 by inserting both fingers in the gaps on the edge of the panel and lifting up until the bottom panel comes off of the device.
  4. TDK Life on Record A33 Battery Replacement: 步骤 4 中的图像 1,3 TDK Life on Record A33 Battery Replacement: 步骤 4 中的图像 2,3 TDK Life on Record A33 Battery Replacement: 步骤 4 中的图像 3,3
    • Do not rip the wires connecting the A33 to the battery when removing the battery from the device.
    • Remove the old battery from its housing in the A33 by holding the device up and gently tapping the bottom on your hand until the battery pops out of the A33.
    • When putting the battery back in, make sure it is flat and the wires are pushed into the space along the side. This will make reinstalling the panel much easier
  5. TDK Life on Record A33 Battery Replacement: 步骤 5 中的图像 1,2 TDK Life on Record A33 Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the old battery from the plug that is attached to the device by grabbing both ends of the plug and pulling them apart.
结论
20等其他人完成本指南。
Matthew Festa
于10/16/15注册
808 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-2, Catania Fall 2015 UMass Dartmouth, Team 4-2, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G2
4 名成员
创作了5篇指南
5条评论
This was a GREAT tutorial.
I did find on step 3 that I could not dislodge the cover with my fingernails. I had to use a jeweler's screwdriver to carefully pry it loose. I also found that it was easier to put the new battery in flat end first and then laying it down and putting the wires into the pocket.
Thanks for sharing.
Tom Scott - 回复
Beautifully done, 5 star
Don Rocklin - 回复
I can’t get the screws to come out for anything! Have tried T4 screwdriver plus other sizes, but they won’t budge. Any tips? It’s driving me crazy as I have a new battery ready to go.
rhianne - 回复
Use the T5 Not T4
anonymous 3628 - 回复
Just completed. Great directions though mine required a T5 torx bit, not T4.
Henry - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 41
过去 30 天: 83
总计 22,335
