跳转到主内容
TDK Life on Record A33 AC Adapter Prongs Replacement
你所需要的
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: 步骤 1 中的图像 1,1
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: 步骤 2 中的图像 1,2 TDK Life on Record A33 AC Adapter Prongs Replacement: 步骤 2 中的图像 2,2
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: 步骤 3 中的图像 1,1
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
结论
另外一个人完成了本指南。
Matthew Festa
于10/16/15注册
808 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-2, Catania Fall 2015 UMass Dartmouth, Team 4-2, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 2,561
