跳转到主内容
TDK Life on Record A26 Front Faceplate Replacement
你所需要的
  1. TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: 步骤 1 中的图像 1,2 TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: 步骤 1 中的图像 2,2
    • Obtain the black plastic spudger to remove the faceplate.
    • Insert the pointed end of the tool inside one of the holes on the faceplate itself.
    • The corner is the best place to start.
    • The faceplate has many little holes so choose one that makes it easier for you.
  2. TDK Life on Record A26 Front Faceplate Replacement: 步骤 2 中的图像 1,3 TDK Life on Record A26 Front Faceplate Replacement: 步骤 2 中的图像 2,3 TDK Life on Record A26 Front Faceplate Replacement: 步骤 2 中的图像 3,3
    • Gently start to lift until the faceplate starts to rise.
    • If you are having trouble getting the faceplate off, continue trying on the rest of the corners until fully removed.
结论
4等其他人完成本指南。
Elise Howard
于10/13/15注册
831 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 482
