跳转到主内容
TDK Life on Record A26 Battery Replacement
你所需要的
  1. TDK Life on Record A26 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Get a replacement battery from the TDK company. The battery part number is E23-00059-01.
  2. TDK Life on Record A26 Battery Replacement: 步骤 2 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 2 中的图像 2,2
    • Obtain the screwdriver and the T09 (Torx) bit from the iFixit toolkit and assemble them together.
  3. TDK Life on Record A26 Battery Replacement: 步骤 3 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 3 中的图像 2,2
    • Use the T09-bit screwdriver to remove the two 8-mm torx screws on the bottom strip of the speaker.
  4. TDK Life on Record A26 Battery Replacement: 步骤 4 中的图像 1,3 TDK Life on Record A26 Battery Replacement: 步骤 4 中的图像 2,3 TDK Life on Record A26 Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the faceplate by using the pointy side of the black plastic spudger.
    • Stick the point of the spudger into one of the corners surrounding the faceplate and gently pull it up.
  5. TDK Life on Record A26 Battery Replacement: 步骤 5 中的图像 1,1
    • Then exchange the T09 bit for a PH1 bit
  6. TDK Life on Record A26 Battery Replacement: 步骤 6 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 6 中的图像 2,2
    • Use the PH1-bit screwdriver to remove the eight 11-mm Phillips head screws that are located behind the faceplate.
  7. TDK Life on Record A26 Battery Replacement: 步骤 7 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the one 7-mm Phillips head screw located on the lower left of the front of the speaker with the PH1-bit screwdriver.
  8. TDK Life on Record A26 Battery Replacement: 步骤 8 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 8 中的图像 2,2
    • After all screws are removed, turn the speaker over to the back of the speaker.
  9. TDK Life on Record A26 Battery Replacement: 步骤 9 中的图像 1,3 TDK Life on Record A26 Battery Replacement: 步骤 9 中的图像 2,3 TDK Life on Record A26 Battery Replacement: 步骤 9 中的图像 3,3
    • Use the blue plastic opening tool from the toolkit to pry off the back of the speaker, gradually moving around the device.
    • Make sure to open it evenly on all sides.
  10. TDK Life on Record A26 Battery Replacement: 步骤 10 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 10 中的图像 2,2
    • Then remove the bottom narrow strip of plastic to uncover the battery.
  11. TDK Life on Record A26 Battery Replacement: 步骤 11 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 11 中的图像 2,2
    • Follow the red, black, and white wires attached to the green battery sleeve down to the white small plug.
  12. TDK Life on Record A26 Battery Replacement: 步骤 12 中的图像 1,2 TDK Life on Record A26 Battery Replacement: 步骤 12 中的图像 2,2
    • Once you have found the white plug, gently grip the colored wires and carefully pull to remove the white plug from the speaker.
结论
9等其他人完成本指南。
Elise Howard
于10/13/15注册
831 声望
创作了3篇指南
团队
2条评论
This procedure is totally unnecessary! TDK has much simpler instructions. http://downloads.imationsupport.com/lor/...
Marty F - 回复
Actually, this page DID help me as the other “simpler” instrucions didn’t work, as I was unable to slide the battery cover after removing the two screws.In any case the entire procedure only took about ten minutes, so THANK YOU!
Sander - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 49
总计 6,993
