跳转到主内容
TCA Quadrant Flash and re-install the firmware
你所需要的
    • Download and install the driver package from here.
    • Both the Sidestick and the Quadrant are using the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your Quadrant from USB if you already have it plugged-in
  1. TCA Quadrant Flash and re-install the firmware, Press and hold the indicated button.: 步骤 4 中的图像 1,1
    • Press and hold the button highlighted in the image.
    • Keep holding the button and connect the Quadrant directly to USB port of your PC.
    • Connection must go directly to USB port of your PC and not through the Sidestick
    • Your Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
终点
Formica Fusca
于08/01/24注册
2,595 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 379
