跳转到主内容
TC-WE825S Power Button Replacement
你所需要的
  1. TC-WE825S Power Button Replacement, TC-WE825S Power Button: 步骤 1 中的图像 1,3 TC-WE825S Power Button Replacement, TC-WE825S Power Button: 步骤 1 中的图像 2,3 TC-WE825S Power Button Replacement, TC-WE825S Power Button: 步骤 1 中的图像 3,3
    • Unscrew the 8mm Phillips head screws from the left and right sides of the cassette player.
  2. TC-WE825S Power Button Replacement: 步骤 2 中的图像 1,3 TC-WE825S Power Button Replacement: 步骤 2 中的图像 2,3 TC-WE825S Power Button Replacement: 步骤 2 中的图像 3,3
    • Unscrew the 8mm Phillips head screw from the back of the cassette panel. Remove the cover.
  3. TC-WE825S Power Button Replacement: 步骤 3 中的图像 1,3 TC-WE825S Power Button Replacement: 步骤 3 中的图像 2,3 TC-WE825S Power Button Replacement: 步骤 3 中的图像 3,3
    • Locate the power cord connection and disconnect it. To remove it, press down on the plastic tab and slowly slide it out of the socket.
  4. TC-WE825S Power Button Replacement: 步骤 4 中的图像 1,2 TC-WE825S Power Button Replacement: 步骤 4 中的图像 2,2
    • Locate the cords that are connected to the power button. Remove the connection by tugging on the cords gently, releasing them from the main PC board.
  5. TC-WE825S Power Button Replacement: 步骤 5 中的图像 1,1
    • Unscrew all five 7.5mm Phillips head screws from the PCB (printed circuit board) behind the power switch.
  6. TC-WE825S Power Button Replacement: 步骤 6 中的图像 1,1
    • Use forceps to gently pry the PCB from the frame of the cassette player.
  7. TC-WE825S Power Button Replacement: 步骤 7 中的图像 1,3 TC-WE825S Power Button Replacement: 步骤 7 中的图像 2,3 TC-WE825S Power Button Replacement: 步骤 7 中的图像 3,3
    • Use a soldering iron to desolder the power switch’s terminals and connections. Remove the power switch, replace it, and solder it back together. Repeat these steps in reverse order to put the cassette player back together.
结论
Cameron
于06/01/16注册
108 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 596
