跳转到主内容
T-Mobile Sparq Battery Replacement
你所需要的
  1. T-Mobile Sparq Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
  2. T-Mobile Sparq Battery Replacement: 步骤 2 中的图像 1,1
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
结论
另外一个人完成了本指南。
LeAnn Lewis
于04/07/18注册
539 声望
创作了4篇指南
团队
IUPUI, Team S3-G3, Wilson Spring 2018 IUPUI, Team S3-G3, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S3G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 184
