跳转到主内容
T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement
你所需要的
  1. T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement, Battery: 步骤 1 中的图像 1,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement, Battery: 步骤 1 中的图像 2,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement, Battery: 步骤 1 中的图像 3,3
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 2 中的图像 1,2 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 2 中的图像 2,2
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  3. T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement, Rear Phone Casing: 步骤 3 中的图像 1,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement, Rear Phone Casing: 步骤 3 中的图像 2,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement, Rear Phone Casing: 步骤 3 中的图像 3,3
    • Move the battery and battery cover to the side and pick up the phone.
    • Use the plastic opening tool to remove the camera casing located at the top of the phone.
    • Use your fingers to pull out the gray antenna casing.
  4. T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 4 中的图像 1,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 4 中的图像 2,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 4 中的图像 3,3
    • Hold the phone with one hand and the plastic opening tool with the other.
    • Pry the outer casing off of the phone by wedging the plastic opening tool between the casing and the phone, thus dislocating the tabs.
    • Place the outer casing to the side.
  5. T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 5 中的图像 1,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 5 中的图像 2,3 T-Mobile SDA (HTC Tornado) Rear Phone Casing Replacement: 步骤 5 中的图像 3,3
    • Using the T5 or T6 screwdriver, remove the six screws from the back of the phone, as shown in the first image.
    • Remove the back half of the phone by using the plastic opening tool to pry apart the top half from the bottom half. Wedge the plastic opening tool tool around the edge of the phone to dislocate the tabs.
    • Once the tabs are dislocated, pull the back of the phone apart from the front half.
结论
John Miller
于10/22/12注册
50 声望
创作了4篇指南
团队
Clemson, Team 15-4, Benson Fall 2012 Clemson, Team 15-4, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G4
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 361
