跳转到主内容
T-Mobile REVVL Plus Battery Replacement
你所需要的
  1. T-Mobile REVVL Plus Battery Replacement, Removing the back: 步骤 1 中的图像 1,2 T-Mobile REVVL Plus Battery Replacement, Removing the back: 步骤 1 中的图像 2,2
    • The back of the phone is held on with a combination of plastic clips and adhesive.
    • The entry point is the speaker grille near the bottom of the phone. Be careful not to insert the opening tool directly downward to avoid damaging the speaker.
    • Insert a plastic opening tool in the hole in the back of the phone as shown to lift the back cover.
    • Insert a guitar pick to keep the plastic cover lifted.
  2. T-Mobile REVVL Plus Battery Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Work a guitar pick or opening tool around the edges of the back panel to disengage all clips.
    • There is adhesive around the edges of the back panel as well as around the camera.
    • The fingerprint sensor is attached to the back panel of the phone. Be careful not to rip the flex cable!
    • Insert the hook of a Halberd spudger into the small opening above the plastic part covering the fingerprint sensor and pry it off while covering it so it doesn't go flying away.
    • Disconnect the fingerprint sensor flex cable with the flat end of a Halberd spudger or an opening pick and set the back panel aside.
  3. T-Mobile REVVL Plus Battery Replacement, Removing the midframe: 步骤 3 中的图像 1,3 T-Mobile REVVL Plus Battery Replacement, Removing the midframe: 步骤 3 中的图像 2,3 T-Mobile REVVL Plus Battery Replacement, Removing the midframe: 步骤 3 中的图像 3,3
    • Remove 10 black Philips screws (including one covered by a white sticker below the camera lens).
    • Remove 12 silver Philips screws.
    • Gently peel up the bottom half of the metal tape to reveal...
    • Two more black Philips screws to remove.
  4. T-Mobile REVVL Plus Battery Replacement: 步骤 4 中的图像 1,1
    • The midframe is held on by strong plastic clips around the edges of the phone. Insert an opening tool or pick as shown near the SIM card slot
    • Ensure that all screws have been removed, then work your way around the edges of the phone.
    • Clips near the corners are particularly strong.
  5. T-Mobile REVVL Plus Battery Replacement, Remove the battery: 步骤 5 中的图像 1,1
    • Disconnect the battery flex cable.
    • The battery is held in by 3 vertical strips of adhesive. Use rubbing alcohol and/or heat to soften the adhesive.
    • If you are replacing the screen, skip this step and remove the battery last.
结论
9等其他人完成本指南。
Patrick
于05/14/14注册
6,764 声望
创作了21篇指南
1指南评论
How do I change my charging port on my revel plus Coolpad
Brittney Adams - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 138
总计 22,829
