跳转到主内容
T-Mobile Huawei Prism U8651T LCD Replacement
你所需要的
  1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 步骤 1 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 步骤 1 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 步骤 1 中的图像 3,3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 步骤 2 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 步骤 2 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 步骤 3 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 步骤 3 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 步骤 3 中的图像 3,3
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 步骤 4 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 步骤 4 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 步骤 4 中的图像 3,3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: 步骤 5 中的图像 1,2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: 步骤 5 中的图像 2,2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 步骤 6 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 步骤 6 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 步骤 6 中的图像 3,3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 步骤 7 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 步骤 7 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 步骤 7 中的图像 3,3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 步骤 8 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 步骤 8 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 步骤 8 中的图像 3,3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 步骤 9 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 步骤 9 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 步骤 9 中的图像 3,3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 步骤 10 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 步骤 10 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 步骤 10 中的图像 3,3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 步骤 11 中的图像 1,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 步骤 11 中的图像 2,3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 步骤 11 中的图像 3,3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
结论
另外一个人完成了本指南。
Dillon
于10/23/14注册
578 声望
创作了5篇指南
团队
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G7
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 999
