跳转到主内容
简介
This guide shows how to replace the t-con card which can fail and cause image issues. Replacement parts can cost around $100, the chip is the smd IC U10 AS15-F that regulates the image output.
  1. Find and extract the t-con card being careful since there are flexes and antenna cables that can be damaged. Use precision tools where possible like tweezers to extract carefully. Find and extract the t-con card being careful since there are flexes and antenna cables that can be damaged. Use precision tools where possible like tweezers to extract carefully. Find and extract the t-con card being careful since there are flexes and antenna cables that can be damaged. Use precision tools where possible like tweezers to extract carefully.
    • Find and extract the t-con card being careful since there are flexes and antenna cables that can be damaged. Use precision tools where possible like tweezers to extract carefully.
  2. Once extracted you can place the u10 chip where the old one was located by de-soldering the old chip with a micro-solder technique under a microscope and rework station. Once extracted you can place the u10 chip where the old one was located by de-soldering the old chip with a micro-solder technique under a microscope and rework station. Once extracted you can place the u10 chip where the old one was located by de-soldering the old chip with a micro-solder technique under a microscope and rework station.
    • Once extracted you can place the u10 chip where the old one was located by de-soldering the old chip with a micro-solder technique under a microscope and rework station.
    • Description of the full process and repair explained short and simply
结论
Assembly is the reverse of disassembly
3等其他人完成本指南。
特别感谢这些译者︰
100%
Juan Lara正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
附加文件
Emil Ciavatta
于2015年03月11日注册
71 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 35
过去的30天: 133
总计 651
