跳转到主内容
加入维修社区 - 创建账户
System76 Darter Pro Battery Replacement
你所需要的
  1. System76 Darter Pro Battery Replacement, Remove the Cover: 步骤 1 中的图像 1,3 System76 Darter Pro Battery Replacement, Remove the Cover: 步骤 1 中的图像 2,3 System76 Darter Pro Battery Replacement, Remove the Cover: 步骤 1 中的图像 3,3
    • First, you need to remove the back cover. Flip over the laptop and remove all the screws. Keep each size screw separate. There are 10 short M2 perimeter screws, 2 large M2 keyboard screws, 2 large M2 screws near the hinges, and 1 large M2 center screw.
    • Once the screws are removed, you can open up the cover. Using a flat spudger, begin to pry open the cover near one of the hinges. Work your way around with the spudger and your fingers, loosening the cover until it comes free.
  2. System76 Darter Pro Battery Replacement, Disconnect the battery: 步骤 2 中的图像 1,1
    • Using the flat end of a plastic spudger (never metal), gently disconnect the white battery connector from the logic board.
  3. System76 Darter Pro Battery Replacement, Remove the battery: 步骤 3 中的图像 1,2 System76 Darter Pro Battery Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • There are no screws holding in the battery, only double-sided sticky tape. It's extremely strong and can take some time to remove. The best way is to slide a credit card or thin plastic object between the battery and the tape, slowly loosening it until it comes up.
    • I do not recommended using heat to loosen the tape! Heat can potentially increase the battery swelling and be dangerous.
    • There are only three sticky areas under the battery; one strip on each side and one in the middle. It's helpful if you have extra cards to insert between the battery and the tape once you pry it up — otherwise you'll have to pry each section up again after loosening.
    • Place the new battery on top of the tape, and plug in the connector.
结论
DJ Billings
于05/04/22注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 49
总计 881
