跳转到主内容
Syntus ST150 Ultrasonic Plate Replacement
你所需要的
  1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: 步骤 1 中的图像 1,1
    • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
    • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
  2. Syntus ST150 Ultrasonic Plate Replacement: 步骤 2 中的图像 1,2 Syntus ST150 Ultrasonic Plate Replacement: 步骤 2 中的图像 2,2
    • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
  3. Syntus ST150 Ultrasonic Plate Replacement: 步骤 3 中的图像 1,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 3 中的图像 2,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 3 中的图像 3,3
    • Lift the water tank while holding the base of the diffuser.
    • Disconnect the three cables form the board.
    • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
  4. Syntus ST150 Ultrasonic Plate Replacement: 步骤 4 中的图像 1,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 4 中的图像 2,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 4 中的图像 3,3
    • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
  5. Syntus ST150 Ultrasonic Plate Replacement: 步骤 5 中的图像 1,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 5 中的图像 2,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 5 中的图像 3,3
    • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
    • Remove the cover to expose the ultrasonic sensor.
  6. Syntus ST150 Ultrasonic Plate Replacement: 步骤 6 中的图像 1,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 6 中的图像 2,3 Syntus ST150 Ultrasonic Plate Replacement: 步骤 6 中的图像 3,3
    • Detach the ultrasonic sensor from the water tank.
    • Detach the ultrasonic sensor connector from the board.
  7. Syntus ST150 Ultrasonic Plate Replacement: 步骤 7 中的图像 1,1
    • Remove the rubber cover from the ultrasonic plate.
  8. Syntus ST150 Ultrasonic Plate Replacement: 步骤 8 中的图像 1,1
    • Now you can replace the ultrasonic plate of your diffuser.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 36
总计 558
