跳转到主内容
Sylvania SDVD9004 CD Drive Replacement
你所需要的
  1. Sylvania SDVD9004 CD Drive Replacement, CD Drive: 步骤 1 中的图像 1,3 Sylvania SDVD9004 CD Drive Replacement, CD Drive: 步骤 1 中的图像 2,3 Sylvania SDVD9004 CD Drive Replacement, CD Drive: 步骤 1 中的图像 3,3
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  2. Sylvania SDVD9004 CD Drive Replacement: 步骤 2 中的图像 1,1
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  3. Sylvania SDVD9004 CD Drive Replacement: 步骤 3 中的图像 1,1
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
结论
Sarah Henry
于10/31/16注册
417 声望
创作了4篇指南
团队
Baylor, Team 5-10, Williams Fall 2016 Baylor, Team 5-10, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G10
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 579
