跳转到主内容
加入维修社区 - 创建账户
Swimming Pool Diving Board Replacement
你所需要的
  1. Swimming Pool Diving Board Replacement, Diving Board: 步骤 1 中的图像 1,3 Swimming Pool Diving Board Replacement, Diving Board: 步骤 1 中的图像 2,3 Swimming Pool Diving Board Replacement, Diving Board: 步骤 1 中的图像 3,3
    • Using a ratchet, 5/16" Allen hex socket, and 3/4" box wrench, unscrew the fastener where the diving board meets the top of the spring.
  2. Swimming Pool Diving Board Replacement: 步骤 2 中的图像 1,3 Swimming Pool Diving Board Replacement: 步骤 2 中的图像 2,3 Swimming Pool Diving Board Replacement: 步骤 2 中的图像 3,3
    • Use a ratchet and 15/16" short socket to unthread the 4 hex head fasteners from the fiber glass base.
  3. Swimming Pool Diving Board Replacement: 步骤 3 中的图像 1,3 Swimming Pool Diving Board Replacement: 步骤 3 中的图像 2,3 Swimming Pool Diving Board Replacement: 步骤 3 中的图像 3,3
    • After 4 nylock hex head fasteners have been removed, lift the fiber glass base from the 4 threaded studs that are protruding from the concrete.
  4. Swimming Pool Diving Board Replacement: 步骤 4 中的图像 1,3 Swimming Pool Diving Board Replacement: 步骤 4 中的图像 2,3 Swimming Pool Diving Board Replacement: 步骤 4 中的图像 3,3
    • Remove 2 fasteners where the diving board meets the fiber glass base using the 5/16" Allen hex socket and the 3/4" hex nylock nut.
    • Set the base and board on a stable elevated surface like a table to make it easy to access the parts under the base.
  5. Swimming Pool Diving Board Replacement: 步骤 5 中的图像 1,3 Swimming Pool Diving Board Replacement: 步骤 5 中的图像 2,3 Swimming Pool Diving Board Replacement: 步骤 5 中的图像 3,3
    • To attach the new diving board, fasten the fiber glass base to the diving board using button head bolts, washers, gaskets, and nylock nuts.
    • Do not fasten the board to the fiber glass base too tightly as jumping on it while it is too tight can overload the diving board.
  6. Swimming Pool Diving Board Replacement: 步骤 6 中的图像 1,2 Swimming Pool Diving Board Replacement: 步骤 6 中的图像 2,2
    • Mount the base with the new diving board back onto the 4 threaded studs protruding from the ground.
  7. Swimming Pool Diving Board Replacement: 步骤 7 中的图像 1,3 Swimming Pool Diving Board Replacement: 步骤 7 中的图像 2,3 Swimming Pool Diving Board Replacement: 步骤 7 中的图像 3,3
    • Thread the 15/16" nylock nuts and washers onto stud anchors.
  8. Swimming Pool Diving Board Replacement: 步骤 8 中的图像 1,3 Swimming Pool Diving Board Replacement: 步骤 8 中的图像 2,3 Swimming Pool Diving Board Replacement: 步骤 8 中的图像 3,3
    • Using a ratchet, 5/16" Allen hex socket, and 3/4" box wrench, screw on the fastener where the diving board meets the top of the spring.
结论
Now that you have replaced your diving board, make sure to test it out! That spring will give you a greater bounce than a traditional diving board!
Michael Rodriguez
于10/25/23注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-20, Kershman Fall 2023 CSU Los Angeles, Team 4-20, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G20
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 714
