简介
This repair guide is to replace the microphone for the Swann Wi-Fi Indoor Security Camera. Common symptoms of a faulty microphone can be found in the troubleshooting page for the device here. It is recommended to use a Phillips #0 screwdriver to remove the screws.
This repair guide requires the handling of electrical components that may be sensitive to ESD (Electrostatic Discharge), so proper ESD protection is also advised.
你所需要的
Locate microphone and pull to dislodge from the holder.
Disconnect the connector located on the main board to finish disconnecting the microphone.
