跳转到主内容
Swann Wi-Fi Indoor Security Camera Microphone Replacement
你所需要的
  1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: 步骤 1 中的图像 1,3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: 步骤 1 中的图像 2,3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: 步骤 1 中的图像 3,3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Microphone Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: 步骤 4 中的图像 1,3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: 步骤 4 中的图像 2,3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: 步骤 4 中的图像 3,3
    • Locate microphone and pull to dislodge from the holder.
    • Disconnect the connector located on the main board to finish disconnecting the microphone.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 741
