跳转到主内容
Swann Wi-Fi Indoor Security Camera Infrared LED Replacement
你所需要的
  1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: 步骤 1 中的图像 1,3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: 步骤 1 中的图像 2,3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: 步骤 1 中的图像 3,3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: 步骤 2 中的图像 1,1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Infrared LED: 步骤 4 中的图像 1,1
    • Facing the inside of the front case, unscrew the three 2.0 mm Phillips #0 black screws located on the back of the LED ring.
  5. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: 步骤 5 中的图像 1,2 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: 步骤 5 中的图像 2,2
    • Release the clip connection connecting the LED ring to the motherboard.
    • Remove the infrared LED assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 1,067
