跳转到主内容
SwagTron T1 Back Panels Replacement
你所需要的
  1. SwagTron T1 Back Panels Replacement, Back Panels: 步骤 1 中的图像 1,1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: 步骤 2 中的图像 1,3 SwagTron T1 Back Panels Replacement: 步骤 2 中的图像 2,3 SwagTron T1 Back Panels Replacement: 步骤 2 中的图像 3,3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: 步骤 3 中的图像 1,3 SwagTron T1 Back Panels Replacement: 步骤 3 中的图像 2,3 SwagTron T1 Back Panels Replacement: 步骤 3 中的图像 3,3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
结论
Adrian Abarca
于04/18/17注册
360 声望
创作了2篇指南
团队
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 664
