跳转到主内容
Suzuki FA50 Moped Exhaust Pipe Replacement
你所需要的
  1. Suzuki FA50 Moped Exhaust Pipe Replacement, Exhaust Pipe: 步骤 1 中的图像 1,1
    • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  2. Suzuki FA50 Moped Exhaust Pipe Replacement: 步骤 2 中的图像 1,1
    • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • Use a 10 mm socket wrench to unscrew the two hex nuts.
  3. Suzuki FA50 Moped Exhaust Pipe Replacement: 步骤 3 中的图像 1,1
    • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
结论
另外一个人完成了本指南。
一条评论
Thanks you very much! Happy Fourth of July.
D4Tay - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 16
总计 6,821
