简介
Sustituye el conjunto del láser de tu unidad de disco óptica. Sustituir el láser requiere que tengas o compres un láser nuevo.
你所需要的
Utiliza la parte plana de una espátula metálica para hacer palanca y quitar las patas de goma que ocultan los tornillos.
Quita los siguientes ocho tornillos que aseguran la carcasa superior con la inferior.
Cuatro tornillos Phillips de 55.4 mm.
Cuatro tornillos Phillips de 18.0 mm.
Quita los cuatro tornillos Phillips de 6.4 mm que sujetan la tapa superior de la unidad de disco óptico.
Levanta y quita la tapa de la unidad de disco óptico.
Para volver a montar tu PlayStation 2 sigue la guía en orden inverso, desde el final hacia arriba.
34等其他人完成本指南。
由衷感谢以下译者:
100%
MemoryOverflow正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
just did the laser replacement, however the playstation still identifies "no data" when game is inserted. it says "reading disk" for a few seconds then nothing else happens. thought?
Have you removed the security solder blob? All new Lenses have this somewhere in the circuitry.
I noticed that many times when you replace a lens it throws of the rotary motor. Some ps2 consoles have only 1 hex adjustment yet others have 2. If you have the covers off and just replaced the lenses you should always plug it back in w/ the top off still and adjust it until you see the disc spinning rapidly and laser is moving back and forth. Another way for calibrating is to remove said disc and if lens and ribbon move all the way forward and all the way back 3 or more times then you are almost done. At that point plug in tv chord and place in a disc if the PlayStation 2 logo comes on and disappears in less than 3 seconds carefully replace all parts and your good to go.
Could you please add the parts you would need to replace this to the parts portion.
Nice guide by the way.
