跳转到主内容
Surfboard Futures Fin Replacement
你所需要的
  1. Surfboard Futures Fin Replacement, Futures Fin: 步骤 1 中的图像 1,3 Surfboard Futures Fin Replacement, Futures Fin: 步骤 1 中的图像 2,3 Surfboard Futures Fin Replacement, Futures Fin: 步骤 1 中的图像 3,3
    • Lay your surfboard down on a flat, durable surface long enough to support the length of your board.
  2. Surfboard Futures Fin Replacement: 步骤 2 中的图像 1,3 Surfboard Futures Fin Replacement: 步骤 2 中的图像 2,3 Surfboard Futures Fin Replacement: 步骤 2 中的图像 3,3
    • Make sure the small screw hole in front of the fin is free of debris and sand.
    • Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside.
  3. Surfboard Futures Fin Replacement: 步骤 3 中的图像 1,2 Surfboard Futures Fin Replacement: 步骤 3 中的图像 2,2
    • Continue turning counter-clockwise until the screw is free.
  4. Surfboard Futures Fin Replacement: 步骤 4 中的图像 1,3 Surfboard Futures Fin Replacement: 步骤 4 中的图像 2,3 Surfboard Futures Fin Replacement: 步骤 4 中的图像 3,3
    • Firmly grasp the fin with one hand and place your other hand on the surfboard for stabilization.
    • Simultaneously lift the fin while tilting it backwards to remove the fin.
  5. Surfboard Futures Fin Replacement: 步骤 5 中的图像 1,2 Surfboard Futures Fin Replacement: 步骤 5 中的图像 2,2
    • Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle.
  6. Surfboard Futures Fin Replacement: 步骤 6 中的图像 1,3 Surfboard Futures Fin Replacement: 步骤 6 中的图像 2,3 Surfboard Futures Fin Replacement: 步骤 6 中的图像 3,3
    • With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
    • Once you feel the back secure, bring the front of the fin down into the slit.
  7. Surfboard Futures Fin Replacement: 步骤 7 中的图像 1,3 Surfboard Futures Fin Replacement: 步骤 7 中的图像 2,3 Surfboard Futures Fin Replacement: 步骤 7 中的图像 3,3
    • Place the screw back into the hole and begin turning clockwise using the key.
    • Continue turning until the screw is tight and won't turn any more.
    • Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
  8. Surfboard Futures Fin Replacement: 步骤 8 中的图像 1,1
    • Make sure the screw can no longer be seen.
    • Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
终点
2等其他人完成本指南。
Hudson Albert
于09/29/15注册
165 声望
撰写一个指南
团队
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015 的会员
CPSU-GREEN-F15S10G3
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 4,675
