跳转到主内容
Surface Laptop Studio SSD Replacement
你所需要的
  1. Surface Laptop Studio SSD Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: 步骤 2 中的图像 1,2 Surface Laptop Studio SSD Replacement: 步骤 2 中的图像 2,2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: 步骤 4 中的图像 1,1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: 步骤 5 中的图像 1,2 Surface Laptop Studio SSD Replacement: 步骤 5 中的图像 2,2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 1,2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 2,2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: 步骤 7 中的图像 1,1
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: 步骤 8 中的图像 1,1
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: 步骤 9 中的图像 1,1
    • Slide the SSD directly out of its socket.
结论
5等其他人完成本指南。
5指南评论
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - 回复
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - 回复
Can you fit a full sized ssd or only the short ones?
Omega_o7 - 回复
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 72
过去 30 天: 335
总计 12,794
