跳转到主内容
Surface Laptop Studio Headphone Jack Replacement
你所需要的
  1. Surface Laptop Studio Headphone Jack Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Headphone Jack Replacement: 步骤 2 中的图像 1,2 Surface Laptop Studio Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Headphone Jack Replacement: 步骤 5 中的图像 1,2 Surface Laptop Studio Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 1,2 Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 2,2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 1,3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 2,3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 3,3
    • Remove the left I/O bracket by unscrewing the the 3 M1109237 Screws with your T3 Torx screwdriver.
  8. Surface Laptop Studio Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Remove the two M1168360 screws on the headphone jack with your T3 Torx screwdriver.
  9. Surface Laptop Studio Headphone Jack Replacement: 步骤 9 中的图像 1,1
    • Flip up the headphone jack's ZIF connector locking flap.
    • Remove the ribbon cable from the port.
  10. Surface Laptop Studio Headphone Jack Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Lift the headphone jack up and out with your tweezers.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 191
