跳转到主内容
Surface Laptop Studio Battery Replacement
你所需要的
  1. Surface Laptop Studio Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Battery Replacement: 步骤 2 中的图像 1,2 Surface Laptop Studio Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Battery Replacement: 步骤 5 中的图像 1,2 Surface Laptop Studio Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 1,2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 2,2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Battery Replacement, Battery: 步骤 7 中的图像 1,2 Surface Laptop Studio Battery Replacement, Battery: 步骤 7 中的图像 2,2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
结论
To reassemble your device, follow the instructions in reverse order.
另外一个人完成了本指南。
3条评论
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - 回复
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 78
过去 30 天: 328
总计 3,634
