跳转到主内容
Supersonic Matrix SC-91MID Screen Replacement
你所需要的
  1. Supersonic Matrix SC-91MID Screen Replacement, Screen: 步骤 1 中的图像 1,2 Supersonic Matrix SC-91MID Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section.
    • Be aware of the ribbon cables when removing the display screen from the main component.
  2. Supersonic Matrix SC-91MID Screen Replacement: 步骤 2 中的图像 1,3 Supersonic Matrix SC-91MID Screen Replacement: 步骤 2 中的图像 2,3 Supersonic Matrix SC-91MID Screen Replacement: 步骤 2 中的图像 3,3
    • Place the plastic opening tool between the metal screen plate and the black front casing.
    • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
  3. Supersonic Matrix SC-91MID Screen Replacement: 步骤 3 中的图像 1,3 Supersonic Matrix SC-91MID Screen Replacement: 步骤 3 中的图像 2,3 Supersonic Matrix SC-91MID Screen Replacement: 步骤 3 中的图像 3,3
    • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
  4. Supersonic Matrix SC-91MID Screen Replacement: 步骤 4 中的图像 1,1
    • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
结论
另外一个人完成了本指南。
Norikuni Nishikawa
于03/31/18注册
139 声望
撰写一个指南
团队
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S1G1
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 412
