跳转到主内容
Supersonic Matrix SC-91MID Motherboard Replacement
你所需要的
  1. Supersonic Matrix SC-91MID Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to separate the screen from the back cover.
  2. Supersonic Matrix SC-91MID Motherboard Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to lift the tab shown in the picture, and remove the orange ribbon from it gently. Repeat for all three ribbons on the device.
  3. Supersonic Matrix SC-91MID Motherboard Replacement: 步骤 3 中的图像 1,2 Supersonic Matrix SC-91MID Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips 1.5 mm screwdriver (Phillips #000) to unscrew the green motherboard from the body at the three points
    • Remove the washers (red)
  4. Supersonic Matrix SC-91MID Motherboard Replacement: 步骤 4 中的图像 1,2 Supersonic Matrix SC-91MID Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a hot soldering tool to desolder the wires connecting the motherboard to the speaker. Desolder the wires connecting the motherboard to the battery.
    • Red: Speakers
    • Orange: Battery
    • Yellow: LED
    • Check if your replacement motherboard comes with an LED. You may have to desolder the LED from your old motherboard and solder it to your replacement.
结论
另外一个人完成了本指南。
Sakshi Labhane
于04/07/18注册
139 声望
撰写一个指南
团队
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S1G1
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 245
