跳转到主内容
Superficial Drywall Ceiling Crack Repair
你所需要的
  1. Superficial Drywall Ceiling Crack Repair, Superficial Drywall Ceiling Crack Repair: 步骤 1 中的图像 1,2 Superficial Drywall Ceiling Crack Repair, Superficial Drywall Ceiling Crack Repair: 步骤 1 中的图像 2,2
    • Use a utility knife or five-in-one to remove loose paint or drywall from inside the crack.
    • Don’t gouge the ceiling but firmly scrape parallel to the crack. Scraping perpendicularly to the crack will only cause more damage.
  2. Superficial Drywall Ceiling Crack Repair: 步骤 2 中的图像 1,3 Superficial Drywall Ceiling Crack Repair: 步骤 2 中的图像 2,3 Superficial Drywall Ceiling Crack Repair: 步骤 2 中的图像 3,3
    • Use mesh tape to tape over the crack.
    • Try to use long pieces of tape, if possible taping the entire crack with one piece.
    • It is also important to keep each piece of tape centered on the crack.
  3. Superficial Drywall Ceiling Crack Repair: 步骤 3 中的图像 1,2 Superficial Drywall Ceiling Crack Repair: 步骤 3 中的图像 2,2
    • Use either a five-in-one or a putty knife to spread the compound.
    • Spread drywall joint compound over the tape so that it appears flat.
    • Use more joint compound than you need rather than less. You will sand off excess later.
    • Make sure to cover the tape completely.
  4. Superficial Drywall Ceiling Crack Repair: 步骤 4 中的图像 1,2 Superficial Drywall Ceiling Crack Repair: 步骤 4 中的图像 2,2
    • After the compound has completely dried sand down any ridges that resulted from the putty knife.
    • This step will be messy! Everything in the room will get some dust on it, so either use dropcloths or be ready to clean when you're done.
    • Also, be careful not to get dust in your eyes, or inhale dust. You may wish to wear goggles and a dust mask.
    • Don’t sand into the tape.
    • You still want the compound to cover the tape and its contours completely.
  5. Superficial Drywall Ceiling Crack Repair: 步骤 5 中的图像 1,1
    • Prime and paint the ceiling.
    • Use a primer and paint that has been matched to your ceiling by a paint shop.
    • The primer can be any color that is the same or lighter than your ceiling color.
结论
It is important to note that a crack in drywall may indicate a more critical problem with the framing in your walls or ceiling. Please do not assume that this repair will prevent further cracking.
25等其他人完成本指南。
团队
Cal Poly, Team 30-1, Green Spring 2015 Cal Poly, Team 30-1, Green Spring 2015 的会员
CPSU-GREEN-S15S30G1
4 名成员
创作了7篇指南
4条评论
Is it ok to remove the excess compound and smooth with a damp sponge?
kjratatat - 回复
I just rocked my third ceiling. The first looked like "before" in some spots; the next 2 are flawless. The secret is to put on very thin layers, and lots of them. Of course this takes a long time to dry each coat. But if you put the mud on thick it will shrink and crack later, plus you have a lot to scrape off and then you still have to fill in low spots.
If you use a sponge first, you can end up with a lumpy mess. Level it with a 12 inch knife until it's nearly flat, then on the last coat skim it over and smooth with the sponge.
James Van Damme - 回复
My popcorn ceiling has peeled. I took away those rough edges. Can I spray on the popcorn ceiling. It's just small sections.
Gloria Smith - 回复
If I was to buy compound from Home Depot or lowe’s, what would I be looking for? Is there a brand that is recommended?
GCots - 回复
添加评论
浏览统计数据:
过去 24 小时: 25
过去 7 天: 147
过去 30 天: 647
总计 135,447
