跳转到主内容
SuperSonic Matrix Mid SC-999 Camera Replacement
你所需要的
  1. SuperSonic Matrix Mid SC-999 Camera Replacement, Opening the Back: 步骤 1 中的图像 1,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Opening the Back: 步骤 1 中的图像 2,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Opening the Back: 步骤 1 中的图像 3,3
    • Open up the back on the tablet.
  2. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Camera: 步骤 2 中的图像 1,2 SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Camera: 步骤 2 中的图像 2,2
    • Locate the camera.
    • Unscrew the two screws.
  3. SuperSonic Matrix Mid SC-999 Camera Replacement, Unscrewing the Cover: 步骤 3 中的图像 1,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Unscrewing the Cover: 步骤 3 中的图像 2,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Unscrewing the Cover: 步骤 3 中的图像 3,3
    • Use the J0 Phillps screw driver to unscrew the the two small screws on either side of the black peice.
  4. SuperSonic Matrix Mid SC-999 Camera Replacement, Opening Up to the Camera: 步骤 4 中的图像 1,2 SuperSonic Matrix Mid SC-999 Camera Replacement, Opening Up to the Camera: 步骤 4 中的图像 2,2
    • Pull the black camera cover off and locate the camera with two gold bands running off upwards and to the right.
  5. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding Where the Camera and Motherboard Meet: 步骤 5 中的图像 1,1
    • Follow the gold band the runs up towards the white and grey box connected to the green plate.
  6. SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Camera from Motherboard: 步骤 6 中的图像 1,2 SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Camera from Motherboard: 步骤 6 中的图像 2,2
    • Use the wedge from step one to lift the grey box up.
    • The grey piece should open up towards you.
  7. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Camera Pt. 2: 步骤 7 中的图像 1,1
    • Now turn your attention back the camera.
  8. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Front Camera: 步骤 8 中的图像 1,1
    • Next, Follow the second gold band to right to the white paper, or the front camra.
  9. SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Front Camera from device: 步骤 9 中的图像 1,1
    • Now, carefully remove the front camera with the same wedge from step one, six, and eight.
  10. SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Back Camera from Device: 步骤 10 中的图像 1,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Back Camera from Device: 步骤 10 中的图像 2,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Back Camera from Device: 步骤 10 中的图像 3,3
    • Use the same wedge used in step one and step six to go under the camera and carefully pry away from the sivler plating.
  11. SuperSonic Matrix Mid SC-999 Camera Replacement, Taking the Camra System Off the Device.: 步骤 11 中的图像 1,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Taking the Camra System Off the Device.: 步骤 11 中的图像 2,3 SuperSonic Matrix Mid SC-999 Camera Replacement, Taking the Camra System Off the Device.: 步骤 11 中的图像 3,3
    • When the camera becomes loose, gental pull up and out to the right to silde the gold band out of the white and grey box.
结论
Logan Robinson
于09/18/18注册
493 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 168
