跳转到主内容
  1. 这个步骤还没有翻译 帮忙翻译一下
    Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Carefully flip the unit back over. Locate the seam. Lift and separate the upper half of the case from the lower half of the case. Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
  4. 这个步骤还没有翻译 帮忙翻译一下
    The power switch is connected to the motherboard near the top left of the console. Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
终点
16等其他人完成本指南。
Cameron Deines
于2010年10月05日注册
694 信誉积分
创作了2篇指南
团队
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G47
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 23
过去的30天: 134
总计 20,966
